It is currently Wed Feb 19, 2020 3:20 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Fri May 30, 2003 11:35 am
Hi,
I want to know if the N/A bin file comming with ghettodyne is working for 450cc injector of stock injector(240cc)???
thanks
PostPosted: Fri May 30, 2003 12:16 pm
The NA map runs our stock 91 Civic Si perfectly - you can not tell the difference between it and the absolute stock program...but you get a few nice features with the NA .BIN - thanks to the hard work of people here!
Kirk
PostPosted: Fri May 30, 2003 12:47 pm
The N/A (naturally aspirated) map is for 240cc stock injectors and contains stock fuel and timing maps from the original PM6 program.
PostPosted: Fri May 30, 2003 11:45 pm
perfect,
That's what i need to know.
I'm very happy to be able to modify my setting for my turbo setup.
thumbs up to the persons who made this beautiful software :)
PostPosted: Sun Jun 29, 2003 7:01 am
what if im still n/a with 450's, or should i just keep using the maphack until im boosted?
PostPosted: Mon Jul 07, 2003 10:10 pm
ok i just realized that i should just use the boost bin cuz its already rescaled and i just wont be using the boost section.
Post Edited (07-12-03 14:18)
