It is currently Mon Jan 27, 2020 6:02 am
 Post subject: Quick ?
PostPosted: Wed Jul 11, 2007 5:52 am
im new on these stuff of reprograming ecu. my questions is can i use a regular usb cable as a datalogger. and what do i need to so my computer reconize it ?
PostPosted: Thu Jul 12, 2007 2:07 am
http://www.moates.net
it's called an HULog. it comes with drivers. works as a USB COM port.
PostPosted: Thu Jul 12, 2007 11:21 pm
Also the reason you can not use a regular USB is because of the signal voltage differance between the ECU and the personal computer. So you have to use a convertor that makes a signal voltage change and enables the two to be able to communicate. This is known as a TTL to RS232, the ECU uses TTL and personal computers use RS232 +. So the easiest and quit possibly the cheepest thing is just buy the hulog, hondalog, or the cable that xenocron has.
Here is a link for both:
http://www.xenocron.com
or
Xenocron sells moates products as well.
Users browsing this forum: Google [Bot] and 24 guests
