It is currently Mon Jan 27, 2020 5:34 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jun 02, 2011 9:22 pm
Get a powered USB hub (without the power supply) and get a 7805 5V regulator from Radio Shack and make the 5V supply input for the hub...+12V in from the switched 12V in the car (and ground) and the 5V voltage regulator output will drive all of the devices connected to the hub. I ran a single 10 foot USB extension cable to make sure that I didn't have any problems (and also so I could be outside of the car when I get to the dyno) and I have never had an issue. The 7805 will supply 5V @ >1.2A...a three port hub needs 500mA max per port...works out perfectly.
It is a handful of parts and it is really easy to build!
Kirk
PostPosted: Sat Jun 04, 2011 7:54 am
now that i`m thinking about it I could use these cheap lighter 5v usb thingies tear it apart and use that as a voltage regulator
PostPosted: Sat Jun 04, 2011 6:42 pm
BINGO! :mrgreen:
Kirk
